Hi Gambo, What i meant is since i will be replacing the tubing i will as well test and correct the amount of material that's being extruded. Just to kill two ducks with one shot sort of speaking.What i've noticed is that when i set layer height at 0.3 my nozzle starts ridding the print. It also happens at 0.2 height but a lot less.I did not tested temperatures for stringing, but issues with bad layering and print riding are present on 190. 20, 210 and 215.So i want to fix that problem as first and than move to smaller issues.
Hi Thanks for the info. I normally print PLA at at latest 220 and on an Ender 3 pro 70mm/S on a 0.4mm dia nozzle and 0.4mm line width.
PRINTING PROPERTIES
Build volume: 220 x 220 x 300 mm.
Min. Layer Height: 0.05 mm.
Frame: Aluminum.
Nozzle Quantity: One.
Nozzle diameter diameter: 0.4 mm.
Max. print temperature: 260?
Nozzle diameter: 1.75 mm.
Connectivity: SD Card, USB.
