So, the next problem is, the printer won't recognize any files on the 8GB flash card.
Do I need to flash Sailfish?
You need to put the other web page on it so you can drag and drop and also delete from the same page.
It is not just a Python script. It is a new front end HTML file.
http://www.extrud3d.com/sites/defaul...AirUI_v0.2.zip
Apparently the Monoprice Creator X rebrand is not compatible with the 8GB Flashair, and they won't even tell me about their firmware.
The info states the firmware is v1.2. I'd like to try Sailfish, but I'll need the stock firmware install to revert, in case of problems.
Can anyone here tell me about this and/or where to get the stock firmware install?
ETA: I did a full format on the card (quick format didn't work) and now the printer can read the .x3g files and connect to the router.
You should still see if Sailfish will work. Go and read "Jetguy" posts in the Wanhao ( and other) google groups. You will probably have to read a lot of tripe but the answers will be there I think.
I can't see any of the clone manufacturers having the resources to write their own software and if they did it would likely be more bug ridden than than a dead tree in a forest.
You will be unlikely to find the original firmware, a lot of these clones you can't but it really is just the standard stuff with additional bits to identify the maker. Start with a picture of your motherboard, is it a Mightyboard, if not what is different etc etc.
Thanks for the pointer. I installed it on my card, but all I see is a page with a list of files on the card.
While that is cool, drag and drop does not seem to work to copy files to the card. I get the download prompt when dropping a file (save or open) but nothing else happens.
Do you have any tips on using this?
