I’ve tried printing with TPU using 225 degree nozzle and 60 degree bed. I’ve tried slowing it down to 15mm per second but i’m getting a very spotty result.
Any suggestions?
Any suggestions?
Gravity feed spool holder with roller bearing so filament move with virtual no force required. If you extruder drive is not just spring loaded, adjust the tension with a test print running. Loosen it, and then very slowly tighten it until the filament starts moving.. then a air more. Thats it..
No retraction
The above is for Ninjaflex, Cheetah is much stiffer and not as much a problem.
Good luck it takes a lot of fiddling but can be done.
225 is nowhere near hot enough for most tpu, and 15mms - depending on what kind of estruder you have - is pretty fast.
For filaflex I think I ended up printing at 250c and 20mms on my i3 - and that's a direct drive !
Also, having your printer upside down, probably isn't helping ;-)
