3 Attachment(s)
FS: Dimension BST 3D printer - $3250
We have a Dimension 3D printer which has very little usage on it. The Printer was used to produce high performance automotive prototype parts for engineering and design purposes. The printer is in good condition, still rather new with little usage. We haven't used it for about a year. The only issue we saw was that after running it after a while, the printer head would produce strain-like deposits (inconsistent printing) and would sometimes get clogged. When we called a technician out to inspect the machine, he recommended replacing the head all together. It might be possible that the head just needs to be re calibrated but it was recommended to replace the printer head. Other than this issue, the printer is in good condition internally and everything else works fine. We are the original owners and the unit was bought directly from Tekpro. All of the internals are present, nothing has been altered, modified or retrofitted.
This is a great value and is honestly worth a lot more than the asking price, but we need to make room at our facility. Specs and info below:
Build Size 8 x 8 x 12 inches (203 x 203 x 305 mm)
• Layer Thickness .007 & .010 inches (.178 or .254 mm)
• Compatibility: Windows® XP / Windows Vista® / Windows® 7
• Network Connectivity: Ethernet TCP/IP 10/100Base-T
• Size and Weight: 27 x 36 x 41 in. (686 x 914 x 1041 mm), 300lbs.
• Power: 110-120 VAC, 60 Hz, minimum15A dedicated circuit
• Regulatory Compliance: CE / ETL
• Special facility requirements: None
Attachment 1536Attachment 1537Attachment 1538
Asking $3250 obo. Please email me kyuan@group-a-eng.com for more information.
