Cura cannot talk to the printer. The printer needs an X3G file and Cura cannot make that, hence the need to convert from Gcode to X3G using RepG.
Hello...
That i know, i used a file converter from here... http://www.thingiverse.com/thing:81425
Using that converter the printer acts like i said...
Regards.
I have spent hours trying to get that converter to work and had no success at all. A lot of people use it without any problems but not I.
Here is a new print... temp used 240 heat bed 55, no stick glue using makerware 2.4... i had to sand out some excessive material in some places to look like this...
Attachment 7802Attachment 7803Attachment 7801Attachment 7804
Well it is a lot better but I still think it is under extruding.
Looks like it warped pretty bad. I had great luck with kapton tape and a very very slow first layer speed with ABS. I've just switched to glass bed with hair spray and thats working good also. Also, switch to Simplify3D ;)
