Quote:
Issue Details Layers shift in the z-direction as print progresses
Cause 1 Printer is printing too fast
Suggested Solutions 1
Lower printing speed
Cause 2 There are loose pulleys on the x-axis and/or y-axis
Suggested Solutions 2
Make sure there is no “play” in the pulleys and tighten
Check to see if there is friction on the pulleys and adjust
Cause 3 Belts are skipping teeth on the x-axis and/or y-axis
Suggested Solutions 3
Check for friction along the entire axis
Check that belts are tight and adjust tension screw
