1 Attachment(s)
What is the largest sand 3D printer you have ever seen?
In my case, the largest 3D printer I've ever seen is the EasyMFG3DP-S2200?Attachment 17285EasyMFG3DP-S2200 ImageEquipment |
Easy3DP-S2200 |
Build Box |
2200mm×1000mmx1000mm |
External Dimensions |
4400mmx2050mmx1900mm |
Precision |
±0.2mm(200mm)±0.1%(L?200mm) |
Tensile Strength |
1-4Mpa |
Surface roughtness |
Be superior Ral12.5 |
Gas Evolution Rate |
12-20ml/g(850) |
Printing Speed |
10-50 s/per layer |
Layer Height |
0.1-0.5mm(can be adjustable) |
Printheads |
four piezoelectric printheads(Can be equipped with up to 8pcs) |
Specicification for printheads |
Length?72mm,resolution:360DPI |
File Format |
STL,3MF |
Electrical Requirements |
Three phase,380V,16A,50HZ |
Powder types |
Silica sand,quartz sand,precoated sand ,etc |
