5 Attachment(s)
[Solved] Multiple oddities
As you may have guessed: I'm new to 3D printing and I'm having issues with my printer. I've done several bed levelings, many many configuration changes, and googled/browsed forums for a few days now. Print qualities have improved only slightly since my first trials, the only thing I managed was to get the second extruder head to stop dragging through my prints.
Printer: CTC Bizer (Dual Head) (I think, it was given to me as a gift, and purchased from an ebay seller without much real data)
Firmware: 7.2 (preinstalled, and reported by ReplicatorG)
Software: ReplicatorG (MakerWare won't successfully print, connects but printing head drags through print)
Settings:
Extruder Temp: 185C-230C (Usually 195 or 200)
Bed Temp: 55C-110C (Usually around 60-65)
Infill: 10 (changing higher and lower doesn't seem to matter)
Layer Height: 0.27
Number of shells: 1
Feedrate: 30 (Just tried 20, doesn't seem to improve much)
Travel Feedrate: 30-90 (Doesn't change much, except minor print time improvements)
The problems are many, but I'll start with the basic ones and move up if we can solve these:
Problem 1: When extruding the "raft" it rarely comes out in good shape (See image 2)
Problem 2: Likely because of problem 1, the first few layers of an object aren't square/don't adhere well? (Happens at all temps/settings)
Problem 3: Objects won't print without raft (printer head seems to drag through them, but they stick up a little almost like it wasn't pressed down into previous layers)
Problem 4: Layers appear to drag/deform As seen on the little stick guy, and the octopus.
Upper layers tend to do better, but not always.
Attachment 8175Attachment 8176Attachment 8177Attachment 8178Attachment 8179
Any help would be much appreciated.
(Note: I work nights, and will be sleeping soon I'll also still be browsing the forums to see if I can find a solution or more info)
