Looking for Zcorp 3D printer users, new owner here... looking for help.
Hello forum,
I just bought a used Zcorp 450 3D printer. It has been in storage for 6 months according to its owner. I have downloaded the manuals and software and intend to go through these carefully. I have searched this web sites forum but found very little on restarting a 450 or similar. I would like to hear from anyone who has done so, in
the past or is currently going through this process. Also any suggestions for sources of print heads and consumables. I have found a firm in Canada that sells come consumables.
I will be sharing my adventure/misadventure on this thread.
Thanks,
Cismontguy
Zprinter 450 kernel error
I have the same Kernel error now and doesn't boot up, may I ask you how did you go around that?
Thanks
Solved the boot up but not the connection
Hey,
Now I could boot it up while the Ethernet cable not plugged in like the same issue here https://www.3dhubs.com/talk/t/z450-n...problems/11262
I tried the fix there by editing the ports to Auto in the BIOS like they said but still didn't solve the problem. I don't have the same amount of ports tho when I access the BIOS, I only see two serial ports and one parallel port to change unlike them in the link above.
Plus when I try to connect the printer to the switch after it booted, the LED lights next to the port don't light up. I don't know if any of that has a meaning. I'm not savvy in electronics.
Do you have any idea?
Thanks
Mo
ZPrinter 450 Software and drivers
Hi, I bought a ZPrinter 450 on a auction but cant find Zprint to download on much info online. Any Advice on what software and drivers that work with this printer and on Windows 10?
