Print Bigger Now
260*260*300 mm / 10.2*10.2*11.8 inch
Print volume of Fullscale XT Plus
is much bigger than
most other 3D printers in the market.
Bigger volume for bigger ideas!http://www.mankati.com/d/file/3d-pri...970b1d6e5a.jpg
http://www.mankati.com/d/file/3d-pri...e1baec9eb9.jpg Print with More Possibilities
Nozzle Temperature up to 300 ℃ / 572℉
High temperature nozzle means
more filament choices,
more applications for 3D printing,
and more fun!
HITP Dual Metal Exturders
High Temperature up to 300 ℃ / 572℉
Dual Extruders
Easy Maintenance
High Resolution Performancehttp://www.mankati.com/d/file/3d-pri...fc4433d259.jpg
http://www.mankati.com/d/file/3d-pri...81b7d23bac.jpg Efficient Cooling System
A Cooling Fan for Each Extruder
A Turbo Fan for Printing Area
High Efficient Fan Drift
Perfect Cooling Performance
Stable & High
Optimized Structure
Smooth Hot End
High Performance Nozzle
Accurate Temperature Control
Easy to be Disassembled and Installedhttp://www.mankati.com/d/file/3d-pri...5a60dfb2ac.jpg
http://www.mankati.com/d/file/3d-pri...9b78185c6a.jpg Accurate Feeder
All Metal Gear Motors
Stable Filament Fixture
High Performance Build Plate
Temperature up to 110 ℃ / 230℉
Short Heating Time
Accurate Temperature Controhttp://www.mankati.com/d/file/3d-pri...2d0b695032.jpg
http://www.mankati.com/d/file/3d-pri...4a7b779e32.jpg
Contact us at sales@mankati.com
or order at http://www.mankati.com/3d-printer/fu...e_XT_Plus.html
Ali express: http://www.aliexpress.com/store/1851550
Closed Printing Volume
Ensures a warm environment to prevent ABS from warping.
