Hello!Is there any setting in Cura That allow printing in 2 parts? So I could use for example PVA for support material and to print my project out of TPU?
supports usually have their own set of settings anyway.
Even cura should do that. plus if you're using a dual extruder - then the second extruder will also have it's own settings. Just tell it to use the second extruder for supports.
You can't print support then print a print with a single extruder printer. as the print head would knock the support out of the way.
Well yes wanted to know if it's possible to do it somehow with a single extruder. I'm planning to use TPU but will try my best to get it clean. But thank you
