4 Attachment(s)
Flashforge Dreamer- 3DMarkt
3DMarkt
http://3dprintboard.com/attachment.p...956609&thumb=1
Evolving the world of innovation and design, the Flashforge Printer combines both excellent quality and extrusion technology to give the user the ultimate 3D printing experience.
Through modern electronic components and additional extras, the user is enabled to produce a range of 3D products with ease and efficiency.
The Flashforge Printer is ideally suited for a range of different enterprises such as design studios, engineering companies or just for private use.
Advanced Features:
- Easily operated – get started within minutes from receiving the machine!
- Print all kinds of materials – Supports ABS, PLA, PVA, HIPS, PET, Nylon and many more!
- Dual-Extruder (2 printer heads) – mix colours or materials
- Faster computing response with ARM Contex- CPU processorBuilt-in Multi Language touch screen deviceBuilt-in WiFi connection – upload your files via WiFi to the internal storage4G built-in MemoryCompatible with Windows XP/7/8 32bit/64bit, Linux and Mac OSUse Flashprint, the unique and easy to use software solution from Flashforge to slice and print your models. Generates the best support structures! Or use Skeinforge and Slic3r for slicing. It is up to you!Firmware can be upgraded to always keep your printer up-to-dateUSB 2.0\32G memory card slotsSealed chamber to prohibit warping and outside interference.
Technical Specifications
- Build Volume: 230*150*140mm
- Printing Speed: ABS: 30-80mm/s PLA: 80-200mm
- Build Platform: 120 C Max
- Filament diameter: 1.75-1.8mm
- Print from: SD Card/USB or Wifi
