2 Attachment(s)
Silhoutte 3D Software questions
Hey guys,
I came across a 3D printer designed for the the crafty people called Silhoutte Alta.
It comes with a suite of design apps which appear to be pretty good for doing tricky stuff.. very easy.
Silhoutte Studio for pulling apart an image for outlines and internals for details and
Silhoutte 3D for manipulating, slicing and printing.
It has this epic feature where you import a 2D image and it asks the import profile. You can select Cookie Cutter and it automatically creates a thicker base, with the outline of the cookie and the end is tapererd or filleted.
See images below.
Problem I have is that it saves the file as a .s3d
I want to be able to create the cookie cutter, convert to .stl and then print through Flashprint on my Adventurer 3.
The Silhoutte program only supports the Alta. I don't want to buy the Alta.
Has anyone come across this, or know how to successfully convert the file types?
Thanks
Steve
