FF Creator Pro Motor Issues
I am having issues with one of my machines extruder motors.
You know how the motor acts when it gets jammed? Tick Tick Tick, and no filament feeding?
Well thats what both motors are doing with no filament in them. I am attaching a video that will show you
what both motors are doing.
At first it was just the right side, I thought maybe the motor was failing, so I pulled the motor from the other side and changed the extruders.
Started the filament load, and that motor does the same thing.
So I was able to just switch sides and print from the left extruder, and in 2 days that side started doing the same thing.
The only error that will pop up after about 3-5 minutes is "Motor To Hot, turn off machine" But it takes 5 minutes for that to happen. So I am assuming thats like a timeout error.
The heat is getting hot to feed the filament, just seems as if the motor is locked up. Both sides.
I am sharing the video from my You Tube Channel
http://youtu.be/G7zFm_uH98c
Have a look and let me know your thoughts please..
Thank You
