HK Turnigy Fabrikator - Upper layers not solid
Hi there,
i got my first printer a few days ago.
Had to fiddle around some time to get it working, but now it starts to print.
My problem however is, that from about 3mm above the bed on, the print is no longer solid. There are no solid walls or ceilings. It just is some sort of wireframe.
Here i have linked a picture of 2 printed objects.
http://ablage.gromotka.eu/IMAG0124.jpg
The Object itself was downloaded from Thingiverse.
I am using Cura 12.12 and 1.76mm PLA.
The printer has a 0.4mm Nozzle.
My settings are (in the order of display in cure):
Layer-thickness:0.1mm
Outer shell width: 1.2mm
Retract: yes
Filling top/bottom: 1.2mm
Filling: 40%
Speed: 50 mm/s
Print-temp: 190C
Bed-Temp: 70C
Support: none
Platform adhesion: none
Diameter of material: 1.76
Feeding (?): 100%
I will start trying to find the cause on my own, but maybe someone here could give me a hint on what causes my problem.
Greetings!
this should fix your problem
[QUOTE=PhilippG;57671]Hi there,
Retract: yes
Filling: 40%
Speed: 50 mm/s
Print-temp: 190C
Bed-Temp: 70C
Support: none
Feeding (?): 100%
Greetings
dump the 15 version of cura and load the older version 14. there is a bug in the 15. i had the same problem and doing this fixed it
