1 Attachment(s)
Underextrusion when there is a drastic section change
Hi there. I have a cr-10S since more than a month ago, after two 1kg spools gone I am still here with the same problem. With items that have a drastic section variation I always have an underextrusion on that layer.
I changed hotend to a V6, changed nozzle, updated the firmware, tried various slicers, but it is still there. I don't know what happens on the max section layers, but something is hidden behind it.
Sometimes they are less evident like in the photo, sometimes it is so hard the top and bottom pieces will just fall apart with a minimal force. It can also happen if there is an internal hole.
In the photo below the underextruded layer is the one where there is the left tip.
Attachment 11894
Thank you.
