Simple Metal stops moving and just extrudes a blob
I just got a Prntrbot Simple Metal the other day and I'm trying to figure out all the stuff it can do. Unfortunately, I've been unable to print anything because it keeps stopping in the middle of a print. what it will do is, just stop moving in the X and Y access, and keep feeding PLA into a blob until a pull the power. Here's a picture of it http://imgur.com/jX381ET
It happens randomly at different points in the print, but so far it has done it on 3 different models and usually on like the third layer in a different spot. That tells me it's most likely not a corrupt STL. when I check the error log it says
Code:
Recv: Error:Line Number is not Last Line Number+1, Last Line: 365
Recv: Resend: 366
Recv: ok
Send: N366G1 X94.757 Y93.944 E27.86820*123
Recv: ok
Send: N367G1 X95.065 Y93.636 E27.88993*112
Communication timeout during printing, forcing a line
Send: M105 T0
But I believe the communication error is because I have unplugged it. The most info I can find on this is a USB cable losing connection, but I would imagine I would hear the windows USB disconnect sound if that happened...
I HAVE successfully managed to print 2 things, which came out kind of crappy, but I can't even begin to get into fine tuning settings if I can't even get it to complete a print >.< Heres my cura settings
Code:
> M501
< echo:Stored settings retrieved
< echo:Steps per unit:
< echo: M92 X80.00 Y80.00 Z2020.00 E96.00
< echo:Maximum feedrates (mm/s):
< echo: M203 X125.00 Y125.00 Z5.00 E14.00
< echo:Maximum Acceleration (mm/s2):
< echo: M201 X2000 Y2000 Z30 E10000
< echo:Acceleration: S=acceleration, T=retract acceleration
< echo: M204 S3000.00 T3000.00
< echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
< echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
< echo:Home offset (mm):
< echo: M206 X0.00 Y0.00 Z0.00
< echo:PID settings:
< echo: M301 P22.20 I1.08 D114.00
< echo:Min position (mm):
< echo: M210 X0.00 Y0.00 Z0.00
< echo:Max position (mm):
< echo: M211 X152.40 Y152.40 Z152.40
< echo:Bed probe offset (mm):
< echo: M212 X25.00 Y0.00 Z-0.20
