Nozzle homing setting
Hi, I'm using a Creality Ender 5 Pro which is modified to produce Direct Ink Writing prints, in which the material constantly flows from the nozzle, unlike FDM printers.
The prints turn out fine, however for the last layer, the nozzle goes in the middle before going back to its home position, causing a line as seen in the picture (https://imgur.com/a/j6BRVCO). Is there a way to adjust the last layer settings in the slicer software so that the nozzle stops at the side of the print instead of going in the middle?
I tried looking in the slicer settings and could only adjust the top layer thickness. I'm using Creality Slicer. Or should I use a different slicing software?
Suggestions are welcome, I'd appreciate it! Thank you!
