2 Attachment(s)
Very strange layer height problem
Over the past few days, I've encountered an interesting problem that I couldn't solve and found out why.
I've been using my home printer for over a year now, with no particular problems. I recently installed slic3r on a new laptop and it worked as before. But then I realized that prusaslic3r can also be configured for non-prusa printers.
Everything worked as expected until one day I started printing and by the time I got back I found only a bunch of molten plastic that barely reminded me of the shape of the object.
I tried the same settings with a 20mm cube. The result was that I got it, one-third as high as it should have been, and of course it was shapeless because it contained as much plastic as a 20mm cube.
When the g code was generated from pc, the result is a perfect cube.
What's even weird is that I get the same bad print from both programs on my laptop.
And i can't find any difference in the g-code when i open it in txt, the layer hight is 0.3 on every z step.
My question is, can this happen because the two program is based on slic3r and somewhere in the libraries things get mixed up?
Has anyone ever had such a problem?
