Thanks a bunch, I'll take a close look at those settings in the morning. And maybe make a new config. Is that what I should do in the absence of an Ender 3 V2 option?
Did you see my screenshots OK?
I saw your pics ok. I made the same box for my deep well mm sockets a while ago using a LQ config.
there are no practical differences between the ender versions.
the mk2 uses a cheaper and less solid frame and - I believe - cheaper, but newer, control board.
But they've done nothing to improve speed - so you'll still need to keep it fairly slow.
Thanks, will experiment along those lines.OT question: when replying to posts the only option I see is ‘reply with quote’.Is that the case for all, implying that quote has to be deleted if not needed?
just use the quick reply box.
Attachment 16137
You won't have the moderator options - but you should have the rest.
After right clicking ; click on multiple model set to get that.
Yes you can do it
