5 Attachment(s)
Anycubic Mega-S Print Quality Problem
Hello everyone. I have been actively working with 3D printers to make molds for more than 2 years. All the machines I have are Anycubic. For about 2 weeks, a print quality problem appeared in the Anycubic Mega-S model, which we could not solve. While the printer prints smoothly up to a certain height, after a certain height it causes distortions in the model as in the images below. The efforts to eliminate the problem so far are as follows:
*The printer was completely disassembled and reassembled, loosened screws were tightened and necessary parts were lubricated.
*Nozzle has been changed
*Table adjustment has been made.
*Tried by increasing the extrusion flow rate from 100% to 105% and 110%, the result was worse.
-The filament we used was 1.75 MM PLA Plus (same problem continued with different brand filaments)
-Bedding temperature 200
-We print with a nozzle temperature of 60.
-Slicer: Cura 4.9.1
I would be very grateful if someone who has had this problem before and was able to solve it. Thanking you in advance.
Attachment 16560
Attachment 16561
Attachment 16562
Attachment 16563
Attachment 16564
