2 Attachment(s)
Aquila printing just fine than hot end raises up and that's-all-folks
Aquila, G32, Cura Slicer, Inland Filament PLA+, printing a large structure (at least large for me) about 200mm x 100mm base area. Initial layer works great, support stuctures outside base area look sound. Prints about 8 - 10 layers (could be 20 layers), flat 200mm x 100mm then one end of a layer gets rough and it prints about 20% of the layer then it raises up and no more printing, only going back and forth. Extruder is not feeding either. I have ironing turned off. Printing at 215C with bed at 60c. I am using a .4 Nozzle ... I did notice that when I use PLA the string that you get wien you load Filament if thick, about .4 but with the PLA+ it is thin, maybe a low at .2 net when loading.Also, after printing, or failing to print either way, when I go back to level my bed, it is very low, takes 2 full turns of the adjustment knobs to bring it back up, all 4 corners. Ideas and solutions welcome.
Added a couple pictures ....
Attachment 17666
Attachment 17665
