Large "Flat" base has major warp... Help!
I am brand new to this forum, and pretty new to 3D printing. I have a FF Creator Pro, I'm using MakerBot software, and have only printed in ABS (white) with rafts so far. I have printed a handful of small to medium size parts of my own design with great results. Also have downloaded some Thingies and those have printed well also. So far so good, until...
My first attempt at a larger part: I have designed a 115 mm cube shaped box with 6 mm thick walls (50% fill) divided into 3 compartments. Each compartment has a sliding lid that snaps into place. I decided to test a much smaller box with the same wall thickness and fill to prove the design concept and find the best print orientation. It printed beautifully and the door snapped into place just as I hoped it would. Time to give the full size box a try...
The print started flawlessly, but when I got to about 30% complete the bottom corners really started to lift off the build plate and curl up. When I cancelled the print at about 38% the corners had curled to the point that they were about 5 mm off the build plate. This obviously ruined the box. I have read that this amount of warp on a print with a large flat base is common. That seems unacceptable... Some people combat this dreaded "corner curl" with small "pucks"or "Mickey Mouse ears" built into the design that are cut off later.
I am planning to try the "puck" concept on the corners with small piers underneath the box. These pieces will not be part of the box, but will be held about 0.2 away. My hope is to lift the base of the box off the BP so that the piers will be sacrificed and the base of the box will hold flat.
Has anyone had any experience with the"pucks" or "piers" strategy for combating these curling and warping problems? Does my "pier" idea make any sense?
Can anyone give me some practical advice? Thanks!
