Hi. How to repair a damaged stl Meshmixer and 3D Builder can't fix it. It is not very visible in that photo, but there are omitted parts of the lines. Slecer I use Simplify3D.
Do you get displayed error indicators in Meshmixer from the file? If you can post the STL, it might be easier to determine a solution than to attempt so from a photo.
Does not display Meshmixer errors. This is a problem I've come across several times. Cura can fix these bugs but fails Simplify3D which I use in which supports well. Since most printers use Cura, they don't know about these defects. I tried to ask, Thanks.
Do you see in the slicer the flaws that appear in the photo? It's difficult to determine from the image what you are determining to be failure points.
The slicer does not show these defects. I searched the internet and these are known defects. Microsoft STL Repair has provided fixes for these defects, but this option is no longer available.
