2 Attachment(s)
Ender 3 Pro with wall/shell issue
I'm having an issue with walls/shells on prints. You can see on both the round and square posts, the diameter changes where the bridges are and in other places where another feature of the model starts or stops (like the small cone on the bridge). I usually use Cura but printed this small temp tower using PrusaSlicer and the problem remains. I've tightened the belts and made sure the table and x move freely. Any ideas on what else I can do or adjust to reduce or eliminate this issue? This is printed at 195C with 60C bed with Hatchbox white PLA (I printed another temp tower sliced to with temp changes from 220 down to 190C and found the best results at 195C). I also have Hatchbox blue PLA and having the same issue. Also getting some echoing. I have the printer sitting on 1/2" of soft foam on top of heavy rubber mats. Layer height .20, Speed is 35mm/s on walls, 60mm/s on infill, travels 80mm/s. Let me know if you need more information. Appreciate any thoughts on this.
EDIT: pay no attention to the top layers in the 2nd pic... I wanted to try the Hilbert curve to see how it would look. It doesn't look as nice as I thought it would, so I'll stick to concentric/lines.
