Originally Posted by
Nitro-Kill
Hi ,,,
I have done a Heat bed modification.. got rid of fixed 6mm alu plate , inserted a new 3mm base heat plate , with a changeable 3mm print bed.. as I was testing to see what heat is exactly coming to the surface of the print plate , i got 92°C.
this means that the reading that I get from my display set at 108°C is 16°C less the what I get on the surface. as I have took out the old 6mm plate ,and forgot to pre test the heat plate (Dohhh). Can somebody give me an actual reading from the middle of the heat plate from the Creator pro, I would be very grateful set temp 108°C.,I let it prewarm with the extruder becase this was standard operating procedure ( approx 10-15 min)
