2 Attachment(s)
CR-10S Missing Layers with Larger Layer Count Help!
Can't tell what's going on. Don't think my nozzle is clogged, took it off and pulled all the stuff out. I see that if the extruded plastic doesn't come out straight when the Z is in the air that I might have a partially clogged nozzle. Mine curls a little. So here is a print I did last night of the Master Spool and my specs. It's missing in lots of spots and some of the layers don't seem bonded real well. I don't think I've ever tried 0.3 layer height and got a really good print. So maybe that is just too high for this machine and/or I'm not setting it up correctly.
0.4mm Nozzle
Brand new eSun PLA PLus 1.75mm Filament
CR-10S Stock
Cura
Level Bed - Did this right before the print.
0.3 Layer Height
0.2 Initial Layer Height
30% Infill
1.2mm Wall Thickness
0.8 Top/Bottom Thickness
Top/Bottom Pattern Lines
220C Temp
60C Bed Temp
100% Flow
60mm/s Print Speed
60mm/s Infill Speed
30mm/s Wall Speed
60mm/s Inner Wall Speed
30mm/s Top/Bottom Speed
120mm/s Travel Speed
30mm/s Inital Layer Speed
100% Cooling
Skirt
I don't see any problems when printing, but I'm not watching it all the time. I haven't seen anything, but I get the impression when I'm using a full roll, 1kg, that it's too much weight, but that's my impression. Maybe this machine can't extrude that fast?
What do you think?
Attachment 11448Attachment 11449
