MonoPrice Dual Extrusion 3D Printer
Monoprice, a California based discount electronics company, today announced the launch of the MonoPrice Dual Extrusion 3D Printer. The printer will cost just $1199, and feature two extruder heads, meaning that printing with multiple colors is possible. The company claims that this is the cheapest dual extrusion printer on the market. Here are some basic specs for MonoPrice's new machine:
Case Color |
Black Powder Coated |
Extruder |
MK-8 Dual Head with upgraded release |
Plate |
Heated Metal Build Plate |
Print Technology |
FDM |
Build Volume |
8.9" x 5.7" x 5.9" (225 x 145 x 150 mm) |
Printing Material |
ABS/PLA/PVA Filament 1.75mm |
Layer Resolution |
±0.10mm |
Positioning Precision |
XY: 11 Microns (0.0004")
Z: 2.5 Microns (0.0001") |
Layer Thickness |
0.1 - 0.5mm |
Nozzle Diameter |
0.40mm |
Printing Speed |
24cc/hour |
Extruder Temp. |
0-250°C |
Heating Plate Temp. |
0-120°C |
Connectivity |
USB Cable, SD Card |
OS Compatibility |
Windows® XP/Vista®/7/8
Linux, Mac® OS X® |
Operation |
LCD Screen + 5 keys control |
AC Input |
100~240 VAC, ~2 amps, 50~60 Hz, 350W |
Dimensions |
18.7" x 12.7" x 15.1" (476 x 322 x 383 mm) |
Weight |
28.7 lbs. (13kg) |
Software |
ReplicatorG |
File Types |
Input:STL/OBJ
Output:X3G |
Further details on this printer can be found here: http://3dprint.com/3678/monoprice-du...ion-3d-printer
Here is a picture of the dual extruders:
http://images.monoprice.com/productl...ges/116143.jpg
