epoxy resin pressure applied to 3d print for bonding + strength??
Hello, new member, and novice 3d printer I'm sure.I was just wondering if anyone has tried to strengthen 3d prints for applications that are in tension or subject to shear using something like an epoxy which is applied and left to cure under pressure (say using a pressure cooker [as the lid can be removed] ) and compressed air fittings installed to pressurise the vesselthis is similar to what they do with carbon fibre curing but I am not going to apply heat just pressure which may force the epoxy into the model and apply a better bond than just a surface adhesion.Does anyone know of a FEA analysis tool that may be able to predict 3d print failure? (Long shot.... but thought I would ask).
