I have a prusa i3. I did the manual bed level and loaded all the preset files that the printer came with. this is what happens when I print.
https://www.youtube.com/watch?v=FldTwIKGQPM
https://www.youtube.com/watch?v=CIwSz2HFKmk
Looks like you have adhesion issues .. if its abs you are using try abs juice (abs dissolved in acetone) if its pla try pva glue
May I ask what material you're using? It's most likely an adhesion issue. You can read this link to solve your problem with regards to proper adhesion. Hope this helps!
