Detailed comparison of the FF Creator Pro upgrades vs. the discontinued Creator X
I received the Creator Pro directly from China a few days ago. It arrived with the Creaor X's installation notes and software. The company is still working on the revised materials.
https://mail.google.com/mail/u/1/?ui...&sz=w1579-h759
Below you can see a detail of the changes between the Creator Pro and the discontinued Creator X.
Limetra
1. Added detachable acrylic top and front covers - makes ABS printing more stable and doesn't affect PLA printing .
https://lh3.googleusercontent.com/-q...hY/s1600/2.pnghttps://lh5.googleusercontent.com/-Q...6s/s1600/1.pnghttps://mail.google.com/mail/u/1/?ui...&sz=w1579-h759https://mail.google.com/mail/u/1/?ui...&sz=w1579-h759
2. Added bottom plate - strengthens the protection of circuit board, improves the usage safety.
https://lh3.googleusercontent.com/-Q...O0/s1600/3.png
3. Upgraded cover plate - strengthens the stability of frame in order to install acrylic front door and top cover.
https://lh3.googleusercontent.com/-Y...600/Image1.jpg
4. Upgraded integration of LCD Screen - use independent mold, make display and key component to be an integration module.Improve the printing interruption problem.
https://lh4.googleusercontent.com/-v...600/Image2.jpg
5. SD card slot moved to the center.
6. Upgraded front plate of the frame, Change to new PVC panel to suit the new bottom frame - upgraded appearance of the front of the machine. Suitable for the new machine structure.
https://lh5.googleusercontent.com/-8...600/Image3.jpg
7. Upgrade of Z axis platform - change alloy-plastic structure platform support into metal structure support. Increases printing stability, upgrades platform, makes the adjusting of the platform easier.
https://lh4.googleusercontent.com/-f...600/Image4.jpg
8. Rail of axis Z upgraded - the diameter of the Z axis rail is upgraded from 8mm to 10mm thus reducing the shaking of the Z axis during print, makes printing more stable and no shift.
https://lh3.googleusercontent.com/-l...600/Image5.jpg
9. Upgraded heating platform - the circuit line of the platform is upgraded. Decreases the preheat time and increases the life of the heat platform.
10. Upgraded motherboard performance - the MCU is upgraded to ATMEGA2560.
11. The firmware is upgraded to Sailfish v7.6 FOR FF-CREATOR. According to the company it increase the effective workspace and is ready for future software expansions. The company says that Sailfish is the best firmware of desktop 3D printing machine so far.
12. Software is upgraded - ReplicatorG is upgraded to Sailfish to match the upgrade of the mother board, position more precisely and improve printing precision.
