4 Attachment(s)
V-Flash FTI-230 3D Printer for sale
Attachment 1729Attachment 1730Attachment 1731Attachment 1732
Used V-Flash FTI-230 personal 3D Printer for sale. Used multiple times and never got parts to print correctly. Great for someone who wants to invest the time into fixing it or can use it for parts. Prefer local buyer in Southern California who can pick up in person. Otherwise, buyer covers cost of shipping.
Item: 3D-Systems V-Flash FTI-230 3D Printer
MSRP: $5000
Price: $800
SOLD AS IS, PRINTER (as pictured) W/ POWER CABLE ONLY!
Video description: http://youtu.be/XRFcyn2lLcY
Brochure: http://www.protocom.cz/files/downloa...-nav-usen.pdf/
“The V-Flash Personal 3D Printer fits right in your office, home or modeling shop and within your budget. V-Flash prints durable plastic parts with a smooth surface finish and true to design detailed features. V-Flash is the most affordable 3D printer available, and with this clearance pricing, it simply can't be beat!”
- Printer Size & Weight :26"W x 27"D x 31"H (660 x 685 x 787 mm) 145 lbs (66 kg)
- Max Build Size :9" x 6 3/4" x 8" (228 x 171 x 203 mm)
- Native Resolution :768 x 1024 DPI (xy)
- Layer Thickness :0.004" (102μm)
- Min Vertical Wall Thickness :approx. 0.025” (0.64mm)
- Ambient Noise :Under 60 dBa (measured 1 m from the printer)
- Material Density:~ 1.11 g/cm3
- Material Tensile Strength :33 MPa
- Material Tensile Modulus :1550 MPa
- Material Elongation:5.0%
- Material Flexural Strength:53 MPa
- Material Flexural Modulus:1700 MPa
- Power Requirements:100-120 VAC 50/60 Hz, 6A; 220-240 VAC 50/60Hz, 3A
- File Support:.STL
- Workstation Requirements: Windows® XP, Windows Vista, Windows® 7
- Regulatory Compliance:CE / cTUVus / RoHS / WEEE
More information can be found here:
http://en.souvr.com/product/200712/340.html
