"Print Mold for this model"-function?
Hello guys!
I was just thinking about an easy function within the software that would make a print that "outline" the 3D model so that you can use it as a cold when the print is finished. For example if you want a certain objekt in gypsum and multiple copies, you could select your model, use the proper wobbly resin, check a box called "Print Mold" and automatically get a print with a certain wall thickness around the 3D model that would be possible to pour liquid gypsym into, let the gypsum harden and then just take it out of the old and pour another fill of gypsum. You get the idea. This would save a lot of work.
