Thanks Chadd for the files. Been printing these parts left and right getting things dialed in. I think I am getting closer. I sent you this pic but I figured I would also post here.
The One thing I am finding is the balance of flow rate is tough! Should I be adjust the filament diameter and the multiplier? I have been doing both but it seems like they would both do the same thing and I am fighting myself. To set the multiplier I was printing a single walled box with a perimeter width of .6. I measured the result vs the called for .6 and did my adjustments there. I also measured the filament in multiple spots to get the diameter.
I have calibrated the steps on the extruder so that 50mm setting actually extrudes 50mm of filament. It seems like if I lower the filament diameter (material going into the machine) and lower the multiplier I am telling the machine to extrude less material twice.
I have successfully gotten my bed to correctly zero out on the z axis and have even begun to play with the ABL a bit. I am not happy with how the bottom layers are turning out in Slic3r and Cura seems to over squish. Both have similar settings as far as initial layer height is concerned.
I also tried to print a cube and the top layer had holes in it. This was printed with Cura. It was a misprint as I intended to print solid and forgot to change the infill. I figured I would jest let it run to see how it did. Not good as you can see.
Slic3r Bottom Layer. Stuck good, just has voids between extrusions.
http://3dprintboard.com/attachment.p...tid=5050&stc=1
Cura bottom layer. Similar settings, good squish. Chad suspects too squished. Lower the width or raise the initial later height perhaps? Ignore the funny lines, just marks from my glue stick.
http://3dprintboard.com/attachment.p...tid=5051&stc=1
Cura Print. Had a .8mm top and botom llayer height which I think wasn't enough with that level of infill.
Sold box test. From the look of it, I need to raise my extrusion multiplier.
