Hi, I would like to know if you know any direct extruder mods that don't steal print volume..Can you recommend some links to buy?
why would any streal print volume ?
Should be as simple as just dropping the extruder on top.
Can you post pics of the hotend and carriage and the extruder.
Pictures from promotional literature never show the stuff you want to see in any detail :-)
i have the tronxy x5sa pro stock... i want to add direct extruder without take any print volume (not even a millimeter ;p) i see many project on thingiverse. what is the best?
can you recommend some links of some direct extruder that takes up little space?
Easiest way to mount a direct extruder so you don't lose any space is to stick the motor and extruder up high, above mounting plate, with a short length of PTFE to get to the hotend.
https://www.thingiverse.com/thing:4216612
The disadvantage is that you can't print too fast, because it's a big lump of extruder mounted high about the carriage.
What product is it?Where can i buy it?
It's the same mod. What have I buy on aliexpress to make this mod?
Ah - I didn't read the explanation.
Personally I''d make my own bracket and pretty sure I could get around having to cut anything.
There is ALWAYS another way to do something - and often an easier and simpler one.
But alas - i have no pictures of the existing mounting to work with ;-)
i think that tronxy x5sa pro came with restricted firmware chitu that need to be changed... the ptfe tube in the bowden make same tricks of few millimeters that make bad retraction print. need to be changed with capricorn xs. the chitu firmware go changed with marlin. i think to go with ender3 v2 to have good print with stock printer
