Think you want a BIBO? Read this first!
I got the dual extruder with laser model from amazon. When i opened the carton a long sharp pointed wire was slipped in the hollow of the corregation of the box flap. I pulled the two sides open and the pointed wire flicker d out and stabbed me in the lip..it broke the skn, it bled. This wire rod ground to a sharp point bibo tells me it is for clearing the nozzle ..amazon tells me the packaging method to cause this dangerous rod poised to fly out in your face is checked by amazon and is approved by amazon! Good thing it did not stab me in the eye. I do worry that because the package comes from china that i may have been contaminated or infected with something. I sent the package to the US CDC for investigation. And so far, amazon refuses to refund me the 700 bucks! The CDC will not return it to me even if i did want it back".....So.....I am OUT 700 bucks and have a swollen lip
1 Attachment(s)
grow a support--(or brain)
i own a cnc machine shop. specialize in working with design engineers to develop thier new products. they send thier "concept" and we refine it into a component or assembly that can be manufactured--economically as possible. The design engineers dont often know "IF" things can be machined ot cast. We help them out. Then machine the components for thier vreation so they can test it and send it to UL for approval. I also have a friend that owns a bronze foundry. I've been printing lost was type patterns for him. Refining the shape/ form in zbrush cad and maya into a form that will cast and burn out nicely. I use the stratasys for that--first print last print every print--is magnificent. perfect every time. I ordered the bibo for running or printing smaller models of these concepts -- to more accurately visualize-- on a screen in cad-- can fool you. it helps to print the components -- hold it in your hand etcetera. we both bought 1 of the bibo dual extruders- steel case- heavy--a good fit for machine shop and foundry environments. I recieved mine first. the harpoon story is above, He finally after 3 weeks of going back and forth with bibo- edits- firmware- trying to get cura to work--finally--But he finally got it printing! If you want to call it that. the prints are hodeous! when one extruder is printing the other extruder is oozing gooplets- that then get dragged into the model. .bibo says lower the temp. he tried and tried- cant stp the gooping and still keep a print going hot enough to extrude. He is sending it back to amazon also.I make full sized cnc's busts too with a scanner and cncs
