Thanks roxy, would I simply be able to add the heated bed to one without it? Say... This one...
http://3dprinterczar.com/shop/3dprin...sa-i3/#reviews
You don't need to add a heated bed. It already has a heated bed. Did you read the technical specifications? It says it has a heated bed in two places:
You should be good to go! And that does look like a nice printer!!! With free shipping!
Prusa i3 Technical Details
- 8″x8″x7.25″ (20cm x 20cm x 18cm) Build Envelope
- RAMPS 1.4 Electronics
- 6mm Acrylic Sheets as Side Support
- 0.4mm J-head MK IV Hotend
- 50 micron Layer Height Aachievable
- MK2A Heated Build Platform
- GT2 Pulley’s and Belts
- 12V 15A Power Supply
- Greg Frost’s Greg’s Extruder
Included in the Prusa i3 Package
Prusa i3 Electronics
- MK2A Heated Built Platform (wires and LED pre-soldered)
Uses laser cut acrylic sheets for frames? Guaranteed to develop stress cracks in 6 months. I would not recommend it. I do not see a current auction for a Aluminum Frame Prusa kit on ebay right now.
plexi-glass is just a tradename for acrylic. same thing roxy.
Have you looked at the SeemeCnc.com RoStock. Its a Deltabot kit and people are loving it for $1000. I bought the Delta Orion assembled for $1350 and love mine. My next printer will be the kit though.
I might jump on this....
https://www.kickstarter.com/projects...bot-3d-printer
They aren't promising delivery on those "Cobblebots" until next year, and that's if everything goes according to plan. Are you sure you wouldn't rather get something that's been out for a while and has a track record? Or failing that, at least a machine that's being shipped now, and not at some point in the misty future?
