MakerBot Announces the Replicator Z18 - $6,499 12x12x18 Build Size!
- MakerBot Replicator Z18 has been announced
Huge Build size. 12 inches X 12 Inches X 18 Inches (tall) 2,592 cubic inch build volume
http://images.scribblelive.com/2014/...d771ba77f8.jpg
You can also make a lot of things at once due to the build size.
Has smart extruder that can tell you when you are out of filament. The smart extruder connects with magnets so it can snap off.
3.5 inch LCD display with vibrant colors. Tells you percentage done for a print. Tells you how much longer it will take to finish.
Can connect via USB cable, Wi-Fi, USB Stick, or Ethernet Cable. Can be shared over a network. Also it is cloud enabled.
Enclosed heated build chamber.
Can be purchased at http://makerbot.com/z18
Ships spring 2014 and is priced at $6,499.
