Newb question: Converting G-code to 1-10 VDC analog signal?
Folks,
I am trying to repurpose a meter by meter XY platform into a 3d printer. The existing system uses linear motors driven by servo amps that get a 1-10 VDC control signal. I have seen a Rambo (?) controller board used on the larger delta printer that appears to control stepper amplifiers. Can it also control servo amps?
I do understand that I am building a system upside down with the XY sitting on the bottom and at high speeds the taller objects will sway like a tree. I am working with what I have.
The existing motion controller is an older two axis delta tau system that is controlled via some proprietary serial commands from a older HMI controller.
Any help is appreciated.
Thanks
Larry
