Im Curious what is the single largest object you folks have sucessfully printed on a i3v?
the 12" i3v has alot of room to print. but i havent seen any pics of anything really big
please post a pic or video if available.
Understand that the 12-inch printer is very new. The first units have just been getting put together in the last week or so.
EDIT: These won't win any prizes, but my largest in the XY were the 8-inch supports at each end of my top-mount spool holder. Printed diagonally on the 8-inch print bed. My tallest Z was the 6-inch Z resonance test print from the Make: 2015 shoot out bench mark objects.
what about on 10" units?
Attachment 4065this the biggest thing i have print so far. :cool::p i have been having some power issues .
Here is my largest print to date (today) on a 8'' bed of the rear mounted spool holder I'm working on. ABS 4mm brim/hairspray, no lifting.
Here is a pyramid I designed in openscad & printed recently on my i3v 10". It has an 8" square base by 7.2" high & 1/4" round tubes. This was printed in PLA without fill with probably a brim of 4. The time from my log file was 5:20:40.
Attachment 4134
Attachment 4161Attachment 4162Attachment 4163
the upper frame for my 15lbs combat robot (Low Blow)
on 12" i3v
print time 4hr 32mins
print settings
using slic3r
walls top and bottom are all 1.5mm thick and 20% infill
layer height at .35 .4mm hexagon using 1.75 Purple PLA Prototype-supply from Toy builders off amazon
print speeds are fast very fast
in / outside prem at 30mm/s internal shells at 120mm/s infill at 180mm rapids at 220mm/s
settings active in printer
jerk xy at 15 accel at 1100 Y Amax at 700 X Amax at 1100
this will be a lot more detailed later on building a Instructables Guide on the build when I'm done.
i will post a like in my build log and post copies of all the firmware i will make clones for the 8 and 10" on Ramps as well
I realize you plan to put some info on instructables, but how about also adding a post to Marlin Motion Related Configuration.h Settings for MakerFarm i3v that explains how you arrived at these settings? I'm especially interested in the 180mm/sec for infill at a 0.35mm layer height. That seems like a lot of extrusion throughput.
Thought I'd add my latest piece. Roughly 200mm x 200mm. Makerbot blue PLA, 0.3 in-fill, with speed around 75mm. Came out pretty well. For some reason the second layer printed higher than the 0.3 I had it set for, resulting in a weird band around the piece, but overall, pretty happy with it so far.
http://3dprintboard.com/attachment.p...tid=4260&stc=1http://3dprintboard.com/attachment.p...tid=4261&stc=1
Ryan
MiniMad-done on an 8" or a 10"? Nice looking part.
Done on a 10". It's pretty decent minus the issue i mentioned about the second layer. It took just a little over 5 hours to print, not sure if that is good or bad, but I'm happy with the quality of it. My goal for this new project is that every part is printable on any printer that has a build volume of 8x8x8. There's 3 more of these frames to be printed, and then onto the other parts of the build ;)
Awesome print! Was that done in multiple prints? PLA?
While not my biggest prints, here are a few that have come off recently:
http://3dprintboard.com/attachment.p...tid=4415&stc=1
http://3dprintboard.com/attachment.p...tid=4416&stc=1
The Rubber band gun, was a single print in PLA. has 4 parts to it
