1 Attachment(s)
Prusa mendel I2 Pronter face Marlin error
Hello people,
I have a prusa mendel I2 printer with a ramps 1.4 board, with one extruda and one heat bed and a Ramps GADGETS3D Sheild. Marlin firmware
My issue is when i connect up my printer to pronterface with it plugged into power and usb, it comes up with this on the side console:
Connecting...
start
Printer is now online.
echo: External Reset
Marlin1.0.0
echo: Last Updated: Nov 11 2014 20:33:05 | Author: (none, default config)
Compiled: Nov 11 2014
echo: Free Memory: 5246 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echo:Steps per unit:
echo: M92 X78.74 Y78.74 Z533.33 E836.00
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z5.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X9000 Y9000 Z100 E10000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo:PID settings:
echo: M301 P22.20 I1.08 D114.00
Error:0
[ERROR] Error:0
: Extruder switched off. MAXTEMP triggered !
Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
[ERROR] Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
And the bit that concerns me is the obvious part " Error:Printer stopped due to errors. "
i have a Acer Aspire 64 bit laptop which i'm using, the printer is set to 115200 baud rate on port 5. here is my copy of firmware which i'm using just incase it is something in there.
Attachment 3433
Also before i was using splinter or something along those lines, and there was no error (but the motors wouldnt move, but make a noise like it was jammed or not strong enough. but since i got the LCD shield i read that i needed marlin, (hoping this would kill two birds in one) but it seems to have created an error. as seen above.
i hope you guys can help me, if you need to you can email me at [email protected]
if i've missed anything out please just say and i'll fill in the gaps :)
Thanks in advance
Kind regards
- Your helpless amature 3D printer owner (Jake B)
