Hi, I'm looking for a clear(ish) filament in either ABS or PLA. Does it even exist out there to buy? I'm trying to make covers for LED bulbs that were put in recessed lighting. They work great and run cold but ugly as sin when they're off.
clear is best in pet plastic. abs and pla arent crystal clear. look at madesolid pet+ or colorfabb xt. both are pet and available in clear. keep in mind that when printed you dont get a crystal clear part.
I would say Colorfabb XT is as clear as filament gets tho,
Maybe Tglass is simulair didnt use em yet.
The Formlabs printer makes very clear parts, but it uses resin, not filament. If this is a major part of what you're doing, though, it might be worth looking into.
Andrew Werby
www.computersculpture.com
X2 on the Taulman 3D T-Glase. As stated above, it is PET, the same plastic they make plastic water bottles from. The Taulman 3D web site gives instructions for how to adjust extrusion profile geometry for best optical clarity.
Thanks for all the help guys. I'm still in a learning curve mode here.
I should have rephrased it as I don't want pure clear but more of "sand blast" look as you find on certain shower doors. I can always sand blast it the inside at the shop if it's too clear. Also, if I go the PET route, can I use the same printer that supports ABS and PLA?
Thanks again for the help!
generally pet can print in any printer than will print pla and abs.
Try the transparent PLA or ABS from Cheap3dfilaments.com ive ordered a few times now from them and they always have consistent quality.
If you want a diffused look, that's what you'll probably get anyway.
Yeah sure. Pet is very easy to print with. Very low warp.
the transparent color? yes, you can find it on amazon: http://www.amazon.com/gp/product/B00MO12D6C
thats pla not pet
This ABS filament clear transparent-3d2print.net/shop/product/abs-transparent-1-75mm is what I’ve found so far. Is this the one you’re looking for? Pretty looks like T-glase, huh?
Hello,Shenzhen Superstar Technology Co.,LTD here,manufacturing and exporting 3D printing filament in China.
The following products might be of your interest :
1
2 3
4
5
1.75/3.0mm PLA
1.75/3.0mm ABS
1.75/3.0mm HIPS
1.75/3.0mm PVA
Good quality and competitive price.Samples are available if you need.
