Wondering if anyone here has tried out Marlin 1.1 yet
and if there were any issues or feedback related to it
I am VERY interested in hearing comments on this. It doesn't matter if it is bug reports, or comments about how easy (or hard) it is to get going. I believe there is an issue with Auto Bed Leveling for Delta printers that do not have a servo. But I haven't had a chance to dig into that. Very soon, I'll have that type of printer so if there is a problem I'll be able to get that fixed.
Well I got it flashed to my rumba board and it's printing out Benchy as we speak. A few observations so far.
The LCD display items are cleaner and easier to read
The "beep" tone is much more quiet
Menus are more streamlined
Dislikes:
Turning the knob to adjust settings works in the opposite direction expected. When rotating clockwise values decrease instead of increase.
That's I have so far, but things are working well now after some pains after i forgot to disable max endstops.
Roxy, if you have time I have a question about Marlin in general with the Rumba board. I have an extra thermistor that I want to use as a chamber temperature sensor but I cannot seem to figure out how to set that up in the firmware. Any ideas?
What type of LCD Display do you have? There was some clean up of the LCD Panel code and there was a lot of discussion about the fact the knob turned the wrong way from what people intuitively think it should do. There was talk of making it configurable but because of all the other changes going on... It was decided to leave it alone until things settle down.
With that said, if you go into ultralcd.cpp and go to about line # 1248 you will see this:
encoderPosition += encoderDiff / ENCODER_PULSES_PER_STEP;
If you change it to:
encoderPosition -= encoderDiff / ENCODER_PULSES_PER_STEP;
I think everything will work the same except the knob will turn the opposite direction.
On the extra thermistor, I'm not sure what happens when you enable it because it isn't controlling anything. But you can turn it on by just #define'ing a thermistor type in Configuration.h Probably, I would turn on
#define TEMP_SENSOR_1 0
With a non-zero thermistor type and just see what happens. (This assumes you have a one extruder machine) And at worst case, you can add a line or two to ultralcd.cpp to display the temperature if it doesn't just show up by itself.
Is G7 in marlin_main?
What is G7 ?
Raster for laser cutters. I just wondered if it had made it into the main source.
I don't think it made it in. Mostly, it is bug fixes that are in Release Candidate #1. There is some restructuring of the firmware to facilitate cleaner code going forward. But there really are not that many new features.
I have the full graphical LCD (reprap discount). Your fix for the knob rotation worked great though it does apply universally, not an issue though.
Also I was able to set my extra thermistor up for my second "extruder" though I did try to set it up as extruder 4. I ran into a lot of issues in the firmware when I enabled a fourth extruder so I decided to just leave it as number 2.
The benchy came out well but I want to run some more tests after I re-do my travel and printing speed settings. Thanks for all the help so far!
So far i have it loaded.
the only thing i cant figure out so far is the Z end stiop.. inversion false / true as coping over my previous setting isnt giving the same result.
I have two Z endstops. one on the Servo arm probe and one on the Z access Rail. they are wired in series or parallel (cant recall)
the one on the Z probe is a cherry switch. that is open when pressed, and the others a regular microswitch that is open when not pressed :)
right now the printer things the Z stop is always being triggered.
not sure what im missing.
If the switches are wired in series, you want them to be in the "Normally Closed" position when printing and not at an end stop. If the switches are in parallel you want them to be in the "Normally Open" position when printing and not at an end stop. But regardless of whether they are in series or parallel, you want both switches to be in the same "Normally something" state when they are away from end stops.
If you don't have them setup this way, you are asking for trouble!!!
I think i figured out the Endstop issue (for now)
The Servo arm position are reveresed in this version of marlin.
I had to switch them compared to my last version. to get them to work properly again.
did the way esteps are calculated change?
Good to see an update to Marlin, nice to know its not been forgotten.
Printed out a test cube, thing came out to within .03mm of spec. Having no issues with Marlin RC so far.
Is the accuracy the same as it was before update?
well its likely my mistake. I basically had to start from scratch for most of my settings as I couldn't find the most recent previous version of marlin I had loaded into my rambo
so many of the values i had were very wrong. ended up having to recalibrate everything to get my esteps, PID
but right now its working great. really needed a tuneup
So far so good! my printer is printing better then ever! I was printing a new extruder bracket and it looked great. unfortunately due to a typo in my ending script. once the print was done. the Hotend went down 10mm into the print instead of raising up 10mm to get out of the way.. oh well. Stupid typo ended up almost ruining a pretty perfect print using petg
Are there two pegs that come up higher than everything else? Or is that closest mound of plastic a result of the nozzle driving into the part? If there are supposed to be two pegs of plastic, it looks like that close one is getting too hot. You can add a cylinder that goes up a little higher than the extruder part just to burn some time between layers. That will let that peg cool down and come out better. Maybe a cylinder that is 1" in diameter would do the trick.
yep there were suppose to be two mounds.. the nozzle and heating element went down. it printed fine. just my gcode error in the ending script
Is marlin 1.1 available for Due with Radds?
What is a Due with Radds ? Marlin should run on pretty much any Arduino board setup for 3D Printers.
