This looks pretty interesting..
https://blog.adafruit.com/2015/03/12...ay-3dprinting/
Could this work on our V Extrusion printers?
That is just dumb. Why take from both sides of the printable area when you could stack as many as would fit at one side in a row.
This video show a better view of how the carriage works.. See here . ...Magnet Driven.
Wow I've never seen anything like that before. It's pretty interesting to watch for sure.
I think the thought is that, the second extruder is parked at the edge of the bed until needed, so it will still ooze, but it will do so away from the active print. Of course, when the head grabs the second extruder it may still have ooze on it, but I assume you could add a small wiper on either side of the bed to clean them off...
You can see the shields in the screenshot
http://3dprintboard.com/attachment.p...tid=5343&stc=1
As it would if they were both at the same side of the bed. The stupid bit is parking one at each end of the bed and needing two pickup mechanisms. That removes two times the extruder width from the printable area. If they were stacked at one end of the bed then the pick up does not need duplicating and you only lose one extruder width from the print area.
Good thread for separating the artists from the engineers. :)
This is the link to all the setup files including stls and slic3r config.
http://www.3d-proto.de/index.php?p=projects#ParkingLot
