ok, i see how ie i can see the 11 hex head fixings but what size are they, as a 2.0 is 2 big and a 1.5 is 2 small i wasnt aware there was anything inbetween those sizes. so could someone tell me how to remove the bolts as i want to remove the alu bed and print on removable glass beds.
on the subject of glass beds what temps do i need for the heated print bed i will only be using pla, i may use some abs to run out what i have. also i have some blu glue stick (pva i think) will that help addesion or make it worse
