Hi, I have a print that is 98% good but has a couple of patches of thin bridging with very small holes. I want to use the part as it was a 14 hour print and its good enough in all other respects. Is there a way to manually add pla to patch up these holes? Any tips?
Im thinking about using a soldering iron with a tube of pla like solder to thicken it up and then sanding it down. Anyone tried this?
Also if anyone can also answer, how the heck are you supposed to remove a print from kapton tape?
Cheers
