Originally Posted by
Pete
Again the top seems to be stretched so I assume this is a software bug, but there is (and I'm afraid you'll need to take my word for this because I don't have mega photography skills) some reasonable and unexpected features:
-There is a well defined doorway in the middle of this picture at the bottom and a window above it and a window on the other side.
-The features of the brickwork are clearly visible although this is difficult to see in any picture
-There is definitely a spiral feature where the staircase should be although the inner double helix is missing
I'll continue to debug, calibrate, fix and contribute. I suspect I have my mirror speed set way too high for starters but this shows that a complex model can make it all the way through the tool chain and into a solid object which is certainly promising this early in my beta stage. I think with all the experience being gained and the improvements being made that the first time prints of real users units will be considerably better than this.
