You can also slip a "helper disk" under the support. It is just a round disc piece about 1-2mm high. I think Makerware has one in their library but you can make your own easily.
guys, the new s3d update just got released first thing this morning. download it and try it out. lots of cool new features.
download here:
http://www.simplify3d.com/downloads/
here is a breakdown of the new features and there is a changelog at the bottom of the page.
http://www.simplify3d.com/simplify3d-v2-2-release/
I just went to the link you provided and it is downloading the 2.1.2 version that I already have, possibly other instructions?
Yep, they must have found an issue and pulled it...
It's back up for download
Hah! Avast! detected a threat and deleted the 64 bit installer...
Sounds like a nice update. Still haven't taken the plunge myself with all the negative comments about dual extrusion features or lack there of in previous versions. If someone has an opportunity to install and try out a dual extrusion and report back that would be awesome.
Ok, just seemed to be an Avast thing. Support said the file was fine, and so just turn off Avast during the install. I did so, and it installed. I turned Avast back on and it checked things out, giving an all clear. (Once again, support response was F-A-S-T)!
Two threads going on S3D, so I'm doing some double posting. Just because I posted the problem in both...
