I understand your thoughts! And I 3/4 agree. The big problem is these one letter variable names cause all kinds of problems. And given the code cost is so minimal to support long parameter names, I'm actually thinking it makes sense to make a transition. After all... If somebody doesn't want to have a longer, clearer variable name in the G29 command, they don't need to use it. But with that said, I'm perfectly fine moving to some parameter names that mean nothing and add no confusion. It will be easy to document that I is the minimum X-Axis coordinate to probe. J is the maximum X-Axis coordinate to probe, etc, etc. What we really are trying to do is set this up so people aren't pulling their hair out trying to get it working. (and longer parameter names would do that just as going with I,J,K & L will do it. )
And perhaps we are worrying too much about the confusion. Anybody that uses this feature is going to be using the slicer (either Cura or Slic3r) Post Processors. The Post Processors will know the correct parameter name for each of the values. So everything will magically work for the user. Right???? (I think and hope so!)
Thanks! Mostly I do this just for fun and I don't need credit... However, being able to make updates is helpful. I sent you a Private Message. But isn't all that stuff public anyways? Anybody that is using a fork in the tree can trace it back to every change that is made and who made it, right?
What are your thoughts on the Post Processors? The problem is even though I'm back proponent of Open Source, I do use MSVC Studio for most of my C code when I'm playing around. I put the whole 'MSVC Solution' into your PlugIn folder. I deliberately made the thing very straight forward C code that uses nothing but generic library functions. It doesn't even have a header file. So it will compile with just about anything. But with that said... I'm wondering if the Open Source fans are going to be hostile about that? I guess if they don't like it, they can spend the time to take the single .C file and set up a GCC environment for it.
