hello,
do you 3dprint this table with double nozzles priter, or just it 3dprinted whole table and stick to the foil with markers? Which technique is printed the svg file represented foil?
thanks,
JR
hello,
thanks,
JR
Hi All,
New here and just picked up a SE cheap. Just wondering if this is still a valid mod for the SE-SP and if anyone has a link to the 3.0.0.1 software?
Thanks in advance
Hi everyone, I found the correct version of the software and installed it. Changed the HEX code. Connected to a scanner. But it tells me it has to download a license? It can get the license for the SE, but not if I tell it I have an SP... Has anyone else had this? Or found a way around it? Specificly it says "the license file does not match the scanner".
